I too broke the lower rear valve cover bolt on the driver's side. Fortunately, it broke at the head of the bolt so I had enough of a stud to try the double-nut trick. After soaking stud for 2 nights with Seafoam Deep Creep penetrating oil and using back and forth motion, the stud wouldn't budge. Because aluminum expands 2x with heat, but you have the concern about warping aluminum with the propane torch, I used a heat gun to warm up the aluminum around the stud for about 5 minutes. I then took a block of ice and held it on the stud for a couple of minutes before I tried to turn the double nut. With back and forth twisting, the stud freed up and I was able to remove it. What a relief! Fortunately I was able to remove all the other bolts, including the ignition coil bolts, without breaking any. I'll clean the threads and use a little anti-seize during reassembly, use new valve cover bolts, and reduce the torque by about 15-20% (except for the spark plugs). Thanks to the great ideas and cautions provided by others on this forum as I proceed with this major 270K mile service including timing belt, hoses, coolant Tee removal, valve clearance check, etc.
