valve adjustment
My experience was with the issue of "performance" with big block Chevy engines with solid lifter cams. We fooled with everything to get the last drop of power out and it kind of makes sense that a tighter valve lash would give you that much more lift and better flow at high RPMs, but there was no significant effect on the dyno or at the track until the lash was approaching zero lash when it went down hill fast.
I've always adjusted mine with the engine running for what that's worth. Anyone else?
That's the only way I do it now. Weekend before last I adjusted the 92 FJ80 with the engine running. So smooth and so quiet.
Well...with the help of this forum. Valve adjustment was successful. Was able to follow that up with carb/ timing adjustment. Vacuum reading prior to all of this was 20 with an occasional drop of 4 inches. Vacuum reading post adjustments is steady between 20-21 inches. Thanks again to everyone who chimed in.
I just adjusted the valves mine today, I did it while the engine was running. I did it ounce with my dad some 30 years ago after doing a valve job on a FJ40. Not the easiest way to do things but its the way that Toyota wants it done. I had 3 exhaust valves way to tight and 1 intake very loose, it really ticked pretty loud. Anyway I must have done a good job cause it runs a lot better and no little pops at the tailpipe when you listen to it.
