Valve adjustment gone wrong...
I got up this morning very early. I put some pork shoulder in the smoker and when the sun came up I planned on adjusting my valves. I got it started and warmed it up fully and pulled the valve cover off. This is what I saw:
vbpgimage.php
Look at the rocker arm bolt in the center. SOB was 3/16" loosened. It tightened up fine, but the one right behind it won't tighten. The small one to the right won't tighten, either. It looks like they are M8x1.50 and M10x1.25. Can anybody confirm this? I went to try to find taps to try to clean the holes out a bit and see if it would work but didn't have any luck. I'm assuming I'm going to have to pull the head and take it to a machine shop to have heli-coils put in?
Check to see if the bolt holes are full of oil. If they are you won't get the bolts to tighten.
74fj40 said:
agreeded, if they do, get like a Q-tip and clean it out, removing the head and getting it helicoiled could be costly, you could also consider getting a used head that is fine. did you check the bolt to see if it was stripped?
Yes, both bolts are damaged. Funny thing is that the threads aren't pulled on the bolt, they're pushed. Say if you hold the bolt horizontally with the head to the right and the threads to the left. The threads on the end of the bolt are actually angled to the right instead of the left like they would be if it were overtorqued. I guess I'll start looking for a used head. Anybody know approximately how much it costs to ship a head? It'd be pretty heavy...
They are supposed to be 10x1.25 and 8x1.25. If the one is 10x1.50, that would explain the crushed looking threads.
Pull the rocker assembly off, clean & chase the threaded holes and try installing brand new bolts from Toyota (not from the hardware store!). Use a torque wrench and sneak up on the torque spec, see if they hold. You may get lucky and not have to do anything else.
Are you sure of those threads? All the 8x1.50 bolts match and all the 10x1.25 bolts match, also. There's not an odd bolt thrown in there or anything.
On the torque spec, the factory f motor manual says 25-30 ft lbs, but in the SOR catalog it says 18 ft lbs. :confused:
Here are the pictures of the bolts. The first is of the M8 bolt, showing the 7 stamped on the head. Did the factory bolts have the 7?
attachment.php
Here's a picture of both the M8 and M10 bolts, you can definitely see the M8 is coarser:
attachment.php
It's all about the red lock-tite. If you're going to write off the heads anyway it's worth trying. If you really think the heads are junk you can JB weld them in (then you know they are trash). I would agree with the crowd though; oil filled holes and a gorilla at the wrench. I ran into the same thing when I rebuilt the engine in my wifes range rover (at 80k I was the SECOND guy in the block). I used copious amounts of red lock-tite and ran it until I sold it. That was two years and 15K later; still holding strong.
If the hole threads are damaged you don't need heli-coils. Just go to the next size bolt, drill and tap. Save yourself a few dinaros.
8x1.25 is the standard 8mm thread size, the size of the small bolts.
8x1.5 would be a very coarse thread.
The big bolts (and studs) are 10mm diameter, 1.25 pitch, fine thread.
AFAIK, all 12 port heads (1968-newer) use these sizes on the rockers.
Hold the 8mm and 10mm threads against each other. If they have the same pitch, they will "mesh" together.
Torque is 28pounds/feet for the 10mm fasteners, 18# for the small 8mm bolts.
HTH.
I found out that the smaller bolts that were used were actually 5/16"x18. I got some new bolts, had to run a tap through one of the 10mm holes and the new bolts worked great. Torqued everything down, adjusted the valves, and it works great. It was cool to start it up with the valve cover off and watch the valves actuate and the oil flowing through the rocker arms.
A happy ending - I'm misting up...:D
You forgot to curse the PO who did that...
Kirk
