VAF Problems
Seattle WA
I did a dumb thing and pulled the two screws and connections out of the VAF where the wires plug in. :whoops:.
My truck won't start now (coughs once and dies). When I pulled off the plug into the sensor, it will start but will die when you either blip the throttle or put it in gear.
Anyone know the how the contacts inside the VAF are supposed to look and/or what each connection is for?
Any help would be great.
(92 FJ80 with the almighty 3FE)
Sounds like you have a couple of cracked solder joints, did this on a 4runner years ago. Take a knife and cut the RTV off the black cover and see if you can get in there. IIRC, the board and the wires attach in order, so it should be a fairly straight forward repair. Suggest finding someone who can solder to boards really well, you screw this up, you have to buy a replacement AFM
HTH
Scott Justusson
94 FZJ80 Supercharged
Yah... I've gone through now and done all that... I'm a little confused on "IIRC the board". I think I understand the tabs and the contact sweep etc... but it's still not running... I think I'm destined to buy me a new one. :(
Try putting 12v to the fuel pump directly (using the diagnostic connector is the easiest). Did you do all the resistance tests for the AFM pinouts? I don't think this is a catastrophic loss, but you might be able to find an AFM pretty cheap.
SJ
I'll back up Sumotoy on this and say that I also don't think it's a VAf failure. It's probably a connection/wiring issue.
I usually handle these by first taking the readings of the unit per the FSM to verify that it is functioning properly.
The next step is a little more complicated.
I locate those same test points at the ECM connector and conduct the same tests over again and compare the results.
This way you are evaluating the connectors and harness that runs from the ECM to that device.
Good luck
