vacuum
Plano texas
What is the consensus on vacuum readings when the 80 wont idle.At what rpms do you try to achieve a vacuum reading? At idle readings should be about 16-23 holding steady.However if the cruiser wont idle at all,how does this change? I have to maintain 800 or above rpms so the cruiser wont die. thanks, Mike
I'm a little confused. Are you using vacuum as some sort of metric to determine what's wrong? And this is on a 3FE powered truck?
Moreover, I don't think you should be concerned with how much vacuum the engine is pulling, just that at a steady engine speed, that it's holding steady vacuum.
Does this help or make any sense?
This has new accordian hose.It will not idle .I have the throttle out to 1300rpm to keep it running.A vacuum reading off of the manifold reads a rock steady 22 in.of mer. Thanks,any ideas will be tried. MIke
