Vacuum Tcase Question
Roseville
Just got finished running Rubithon and my Tcase kept popping out of gear. Its a vacuum shifter, I ended up placing a bungie cord on the shifter lever and attached the other end to the roll cage and after this McGyver manuever it worked fine. Obviously something is not working properly, does anyone have any ideas? Other than this problem, seemed to work great - its a 1970 tcase.
Thanks
Fman
Since bungie-cording the hi-low range shift lever (as opposed to the 2wd-4wd vacuum shift knob) stopped the "popping out of gear", the issue sounds like (1) misadjusted or sloppy hi-low shift linkage, or (2) worn hi-low shift fork.
I see from your sig line that you're running a transplant engine and tranny. That raises two more possibilities beyond what crushr suggested.
1.Whoever adapted your linkage system pivot points to work with the v-8 did not calibrate them properly. I have seen a few who have not even bothered to work with the Cheby bellhousing and have mounted the pivot to THE FRAME!:eek: :eek: Those start popping as soon as the engine flexs in the frame.
2. Depending on the final location of the t-case under the rig, the hi-lo lever on the case could be hitting the diagonal tub support that runs just ahead of the gas tank on the passenger side. You can look under the rig in that area for signs of rubbing.
Hth
Mark A.
