Yes, rubber boots. Still available. Toyota 36426-60010 and 36318-60010. The cavity where the shift fork is will get gear oil from the transfer case, but putting some in there before putting back on TC is good. The gasket for the mount is also still available, don't have the number though. The nut on top is for access for oiling the pneumatic shaft, light oil of some kind. Have you checked the vacuum functionality of the unit? If not, put a 3/8 hose on each inlet and suck, one side should pull the shaft in, the other will push it out. If that doesn't work, you'll need to disassemble and assess the issue - maybe the diaphragm, maybe a leak (o-ring referenced above), maybe needs cleaning, or all of the above.
