Vacuum secondary diaphragm
Far North Queensland
have put a new engine fully rebuilt in my 40, it is a 2f out of an 84,60 series,my old motor had a holley and im not familiar with the original carb but i replaced the diaphragm and the metal shaft on the diaphragm is a different length to the one i took out, what is the go and how long is that supposed to be,im confused,at this stage im thinking about going back to the holley but im determined to sort ths carb,maybe a Jim rebuild,thanks
where did you get the new diaphragm you put in to replace the old one? Was the old one bad? Maybe you could just put it back in if it's not bad?
old one was split so ordered one and the metal shaft was longer,dont believe it is right
Not sure of all the differences of the carbs, but maybe you accidently got a diaphragm from a different carb like a 3F carb or something (totally shooting in the dark here). When I went down to my local parts supplier they had the exact right one in the box for my engine. I'd say call them and try to get them to send you the right part.
There are 2 versions of the carb sec. diaphragm.
The 1975-1980 part has a sightly longer, straight shaft.
The 1981-later part has a shorter shaft w/ a small offset at the end.
The diaphragm has to match the spacer block in the carb. If the spacer is thick (~20mm), then the long straight shaft is used. If the spacer is thin (~8mm), then the shorter hooked shaft is used.
HTH!
HTH!
thank you very much,it has been giving me trouble,i will chase the correct part,its what i like about mud,cheers Jim
HTH!
youre the man Jim thanks for that,we have no experts in oz,all the old cruisers are basically gone like the old guys who knew it all,thanks
hello, where can I find a primary vacuum diaphragm for my 1978 FJ40? in picture attached
