Vacuum lines
Houston
After three days of the code "71" I got tired of finding a vacuum line has fallen off with each trip... Yesterday I finished setting the bearing preload on a '95 after a front axle rebuild and then jumped into my '94 with silicone hose in hand.
IT'S A PITA to do without removing anything to gain better access, but possible. I replaced all the vacuum lines except one that is on the inside of the intake housing by the rear most switch by cylinder 6 as I couldn't access it to remove and replace it. All the other vacuum lines were replaced and I have some scratched up swollen hands to prove it! (I have the bracket and vacuum hose assembly that was removed from the '93, so I didn't get things confused when vacuum lines were falling off everywhere.) I can say that Toyota has a LOT of vacuum lines, more than say a '86 Porsche 944 Turbo has and more than any other vehicle I have worked on. (the '95 looks like it runs less vacuum devices, MAF)
The silicone hose was thick walled stuff purchased with a boost gauge sometime back for a seperate vehicle, I do not recommend the auto store generic variety due to collapsing issues. (not sure if it would be a problem in the Toyota though)
So far with 50 miles on the ticker no CEL, a good thing since it's due inspection this month... Yesterday I thought the vacuum lines were OK but still had a 71 which is why I started to replace them all. A note, if the intake is ever removed you can deburr/cut off and grind down a few things that get in the way to make things easier down the road... Much complicated Emissions system. If it comes back i'll make another update.
Just remembered a past thread where the steel toyota hardlines were clogged, wouldn't be a bad idea to disconnect both ends to spray brake cleaner in to dissolve some buildup but so far it looks like mine are clear of obstructions.
BAH!!!! Code 71 popped back up 75 miles later, all vacuum hoses still attached...
Gotcha, found a plethora of information on code 71 after doing a search here. Will pinpoint and correct it when I get a chance. (I have spare parts to use off of the '93 to troubleshoot with.)
Traced the problem to a EGR modulator for now. The OEM one on my truck had a green top, I swapped a blue top one in which had an intact diaphragm and so far so good. (my green top version had a leaky diaphragm in which allowed you to blow through the bottom vacuum connection....) I'll drive it a few hundred miles then order a blue top version.
