Vacuum line?
Wyoming
Hey folks,
I’ve been lurking online for the last few weeks. I was gifted (lucky me!) A 1978FJ 40. My wife it into some trees at age 14 at hunting camp 20 years ago. Her dad said she earned getting it from him when he was done with it. Long story short, it’s been fun as hell to work on over the last couple weeks, and gotten me through the covid up to this point with some sanity.
I’ll keep it brief, but I’ve used a number of the different postings for torque specs, fluid changes, etc. Thanks for the wealth of knowledge, I’m sure I’m just seeing the tip of the iceberg.
Here’s my current challenge: overall runs pretty solid, but doesn’t want to idle without a little bit of choke. I’ve read and watched lots of different bits on cleaning up the issue. I have a vacuum gauge and measure about 14 when I’m plumbed into the intake manifold port. My fuel mixture screw is 4 turns out. That vacuum seems a bit low. Vacuum leak rather than later timing (valves were frequently adjusted).
My question (among many): I have this random vacuum line pictured below unattached to anything. Does this go to the component I’m holding it near? Seems like it does, but I’m not making many assumptions on this vehicle.
Just checked mine, this might not help because mine has most of the smog stuff removed.
If you search around for a minute you can find the factory smog/vacuum routing
Your line goes straight to the intake port. IF mine does go to the component pictured, it would eventually go to that intake port, as the component (not sure what it is) eventually goes to that port.
I believe the hose goes where you think. I'll go check. I've scanned the smog diagram for a Federal truck. If you have a CA or Hi Altitude truck, I can scan those.
Based on these, it looks like I’m suspicions are right. My FIL bought it new in Laramie, WY in 1978, it might be considered high altitude. 7220 elev. Thanks a bunch.
Would that have anything to do with my low vacuum pressure measured at the intake manifold?
Well, it's not the hose I thought it was and it does not hook up to the VCV. The hose from my VCV connects to a fitting at the base of the carb (I have a CA truck). The hose from the carb fitting (that you show in your first photo) also goes to a fitting at the base of the carb. They both see manifold vacuum. With all three versions of smog control, the hose to the VCV always goes to that fitting under the carb.
With that said, I'm not sure where the hose that you show at the carb is supposed to go. It's different for the three versions.
Here is what I found:
Photos from my 78 CA truck. The red hose at the VCV goes to the fitting below the carb, as well as the hose from the carb fitting you show. I'm the only owner, so I know this hasn't been molested.
Hi Altitude smog diagram.
I'll do a little research. Don't hook the hose to the VCV.
I think the connection shown by BHS is correct (indirectly), because it probably went to manifold vacuum below the carb originally, but is still seeing manifold vacuum by it's connection to the gas filter on top of the manifold now.
Do you have an open fitting below your carb?
I have one open fitting under the carb, but oddly the other fitting under the carb is hosed to the EGR valve. That’s different than what I’m seeing from yours. Where should the EGR line be going?
The hose from the EGR valve runs to port #7 of the VSV. That agrees with all three smog diagrams.
Your open port on the carb spacer is a large vacuum leak. I think your unidentified hose from the front of the carb should be hooked to the open fitting on the carb spacer.
Edit: I think the other port on the carb spacer should connect to the VCV. Your EGR valve should connect to port #7 of your VSV.
That all made perfect sense until I found port #7 already had a line running to the BVSV. That line to the BVSV should be Run into the back of the VCV not port #7. Seems like someone got a number of lines switched around. The diagram should help to get things in order.
No expert but might suggest you view Otramm’s YouTube vid titled 2F Aisan Carb Idle Mixture Adjustment. By following his steps I gained 4in of vacuum and an almost perfect idle at 650rpm.
Ive watched that video twice. Started the procedure today...that’s when I notice the first of, now, a few vacuum issues. Need to hammer these out before I go back to tuning the carb.
Quick question before I go “correcting” these lines: is there anyway a handful of lines got switched on purpose? As a way to tune or adjust for high altitude or performance mod? Or did some tech my father in law took it to over the years foolishly mix vacuum lines up? I’ve got 10’ of 1/8” line (hoping that size will work), so I’ll start putting things right in the morning.
Not casting any aspersions on your father-in-law, but in my experience there are a lot of Cruisers running around with half-assed partial de-smog jobs.
Yours could be as simple as someone having removed a few vacuum lines to get to something and not put them back correctly. The answers are in the factory "2F Engine Emission Control Repair Manual", which is available as PDF download here on Mud for free. @spotcruiser has posted some pages of it for you already. If you can't find it to download, I can email you my 1981 copy.
Good. That’s what I was hoping you’d say. Just need to take it back to specs. We’ve modified some Keihin carburetors in Suzuki and Kawasaki’s over the years and if you don’t understand those modifications you’re likely confused. I was wondering if that was my situation with this 40. I doubted it, considering how many open ports are open and lines misplaced. Side note: it’s the federal not the high altitude I’ve determined.
Thanks for all the help folks.
Does it look like the vac line from the ABV should go to the port in the intake manifold?
Long story short, the TP Port was open as well. The ABV was piped to the VSV. The manifold port was into the VSV. The BVSV (Blue) was wrong. The VCV to the carb spacer was non-existent. All that was rerouted and corrected. Got some loose lines in a few spots, and plumbed with 1/8" vac line (which was damn tight) where there was damage.
Drove it around town for a few to warm it up. Came back and had a really smooth idle with no choke necessary. I'll need to run a vac test (I guess on the same manifold port?) and see if that changed much. Probably do the fuel mixture screw carb tuning procedure as well. Thanks for all who assisted in figuring this out. I appreciate your generosity and time.
AK
Most likely the main idling problem was vacuum leak.
AK
