Vacuum hose options
Temecula
I am looking to get some replacement vacuum hose for the cruiser. I know it is metric 3.5mm. Anyone try other than OEM, Possibly better? Mr gasket makes silicone vaccuum hoses that I can get 10' for $12. Also what about the german cloth braided style like VW's use? It seems like that German hose is great quality. Not sure about the silicone. The german hose is easy to get at any VW shop for about $1.25 a foot and is made for high heat.
I thought about the braided stuff before but the reason I decided to go with OEM was because if there is a tear or crack, its easy to get a visual on it. If its braided, you have no idea if there is a crack or break. The silicone stuff I considered as well. Dunno, I may still next time around.
The silicone works well. I changed out all of mine while the head was off. IIRC I had about $30 or so into three different sizes. Most importantly you can choose your color, it may help you get unstuck or be worth 10 seat of the pants horsepower :rolleyes:. In all seriousness I went with it because it will outlast any rubber product and in impervious to all the nasty chemicals under the hood including brake fluid (I use a section for bleeding brakes).
My vote is to just get the goods from Dan the Man, he sells it by the bulk and I like that the OEM stuff has spots on it where you write the number that you want so it is super easy to trace to the right component. HTH :cheers:
Well Im probably going to go the braided route just to be different, plus I like the look. I also found out Old VW fuel line is the perfect fit for the couple larger vacuum lines, I replaced those with some spare fuel line I had laying around. I don't think it will crack anytime soon. Those lines seem to last forever on VW's.
