Vacuum advance
Ohio
Anybody know where to connect the vac advance from the distributor to the carb on a desmogged 2F? Is it where the arrow is?
should be two ports at the base of the carb in between the carb and the valve cover side. Use one of them. Plug that unused port with a rubber cap.
Danny :D
dd113 said:
Look on the valve cover side down low just below or at the same level as the mixture screw.
What he said. Start with the lowest one. If it pings too much, switch to the next highest one. It's that simple!
