Vacuum Advance
Houston, TX
Working on my 78 2F. It is desmogged with stock carb, vacuum advance distributor wth petronix ignition. The PO had plugged the vacuum advance ports at the carb and on the dizzy. Is this correct??? Should i reconnect the VA??
Truck runs ok, but could it run better if i have it hooked up???
Thanks in advance.
Vacuum advance is good. hook it up.
Mark...
Try it and see what happens. My recollection is that '78 distributors are both vacuum advance and retard. They are designed to be electro/mechanically controlled, so I am not sure that they will perform properly without the rest of their control system.
The dist doesn't care where the vacuum comes from. It was routed through all the "crap" as part of the emissions system. But it works just fine when hooked up straight to carb vacuum.
The advance curve is not ideal, but it' beter to have the vac hooked up than not.
Mark...
The dist doesn't care where the vacuum comes from. ...
Yes, but my experience is that the diaphragm spring rates and total advance are different in the electro/mechanical actuators than those designed to operate purely on vacuum alone, so the amount of advance and the vacuum range in which it operates may not be appropriate when it is "hard wired".
No real debate from me that the curve is not ideal. But based on running different engines with the vacuum advance connected and diconnected... better hooked up that not.
Mark...
I overlooked the Pertronics part. I'd make sure that is really is an advance and not a retard now...
Mark...
