Search is not cooperating with me, lookin for V8 swap info. Would be nice if it was in the FAQ
tkx
Ben
tkx
Ben
Thank You
wonder y search didnt bring this back for results
anyway, im thinkin about the V8 swap to make putting a Atlas 4speed easier, was gona be a pain for custom parts to mate to the toyota trans
Ive looked into the GM atlas I5 and I6, 4BT, and duramax
Just doin research
after all said and done with the Engine,trans,xfer gona put 1tons under the chassis
Go with anything GM, dones of support out there for it.
so far its gona be a NV4500 trans and a Atlas 4 speed Xfer.
still torn on V8s
Mopar 5.7 3rd gen Hemi
GM LT or LS
Must be Injected, easy to work on, and parts very easy to get.
What are the big differences between the GM engines stated above?
Is there any less for Ford, Mopar, or Cummins? If he's doing a full drivetrain swap, his options are endless. And all of those manufacturers have plenty of support.
Marks 4wd makes an adapter for a Ford Windsor V8 to A44X and also one for SBC to A44X. The only advantage to the GM engine is Marks also makes engine mounts for a GM engine in an 80. Which, in the whole spectrum of a powertrain swap, is pretty moot.
But fords suck![]()
