woody said:every carb'd motor I ever ran used a stock GM-ish mechnical pump on the PS frontside of the block...mucho cheaper and "just as" reliable as a electric, without the fire hazard when you flop it![]()
kdink79 said:Ok found the plate. How large is the mechanical?
The cross mounting plate is near this.
Also how difficult is it to install.
Rerouting the fuel line will not be that difficult. But what is involved with the installation?
pbgbottle said:you may have the front cradle mount ,which means you have to go with an electric pump . does it look like this one the lower motor mount (cradle mount)
http://cgi.ebay.com/ebaymotors/TOYO...ryZ50454QQrdZ1QQcmdZViewItem#ebayphotohosting
kdink79 said:That's the type of mount I have. So then I need to stay with the electric one.
pbgbottle said:i'm pretty sure ,that would be the easiest unless you change your motor mounts[
Ok then, which ones do you recommend?
would like to use one that others have had success with.
