V8 Conversion/Transmission Question
I have acquired a 71 FJ40 that currently has a 350 and a 3 speed transmission put together with an advanced adapter. My question is can I swap out a four speed transmission in place of the 3 speed with no problems? Is the bolt pattern the same?
Thanks
Which 4sp? The Toyota H42?
The bolt pattern is the same but the bearing retainer is different, so they use different bellhousings (or adaptor plates if you are using a GM bellhousing).
GM 4speeds (sm420, sm465) will bolt right up to a GM bellhousing.
