Used or rebuilt 2f
splitshot
Head cook, Bottle washer, and Peace keeper.
Rodent Central, Az
Ok, so I have a cracked block (post below). Not a big deal till I have to hire a water truck to follow me around. Guess it's time to start looking. I have no buildable core, besides maybe it's time to upgrade to a 2F.
Has anyone had good luck w/sor's used engines or any recommends on a reputible builder?
Also bellhousing-flywheel, F-2F interchangable?
One note: The war department has issued a budget (spouse).
Split, I bought a 2F with 89K on it and decided to rebuild it. New pistons, bored .030 over new cam lifters, etc, etc. Parts and machine work put me about $1300-1400 in it and I reassembled it with the help of a real mechanic.
The 2F will use your F bellhousing, flywheel and clutch assy. But you need to tell the War Department that this is the perfect time to swap to a 4 speed:D
Ed
You can build a 2F. No need to mail order one. Complete, used 2Fs are everywhere. Find the best machine shop in town, for the cost of a stand and a hoist and the parts and the machining you can assemble a fine engine. Follow the instructions in order as listed in the Toyota 2F engine manual. Insert block into rig.
I built a 2F block to replace my late F. Found 8 engines at a machine shop, paid 50 bucks each for them. Took them all apart and used the best pieces to make one engine. Bored 50 over, balanced, fancy head work, race piston rings, RV cam, all the good stuff. Put it all together again. Runs better than new.
You might want to use the front engine mounts from a 2F (bigger bolts). Manifold studs are bigger on the 2F, might need a little grinding to fit your intake & exhaust onto the 2F head. Oil pressure sender location might not be the same as your old engine...minor details. You can do this, you can do this locally. One of the easiest engine swaps imaginable. And with 'Mud on your side, what could go wrong?
I agree with Pighead. I did the same thing. Bought 2 2F's, and mixed and matched the best of both.
Also, any question you have, you will find an answer here. (OK, maybe multiple different answers to the same question.):rolleyes:
Thanks for the info. Hope I can find a good machine shop here in Tucson. The last one I used was excellent but went out of business.
Amen on the 4 Speed.
