USA spec 200 series height
Denver
Does the 200 series height listed by Toyota for the USA model include the roof rack?
I’ve never seen a 200 w/o the roof rack. Is it installed at the factory or port installed?
Looking at buy a 200 late summer. Want to make sure it will fit in our garage built in 1936
Btw my stock 80 series fits with roof rack. Just hoping the 200 isn’t any taller than the 80
Thanks
That's why they make reciprocating saws. ;)
My 200 is no longer stock height, so I can't measure it for you. But, I can tell you that with airbags in the rear springs and with a Thule rack on the factory rack, mine still fits fine in my '50s garage with a 83" high door.
Oh, and a quick search on MUD indicated the rack is factory, not port installed (YMMV).
Thanks. Good to know it’s factory. Toyota says 74 inches. One less than my 80
FWIW, Mine on 285/70-17s, TJM lift and Gobi Stealth rack sits 6'9" (81") at the highest point. I made sure to measure, because some of the parking garages I use(d):frown: are listed at 6'8" and I've seen trucks have to air down just to make it out. No bueno.
I'm pretty sure the height is without the roof rack.
So the Toyota spec listed in the dimensions section of the 200 lists the height as 74 inches. That is w/o the roof rack. Can Anyone with a 2016 or newer 200 series give me an actual measurement of the highest part of the roof rack to the ground?
Thanks in advance
Check out my thread starting in post 34 below. I mounted Maxtrax on top of the stock rack on my lifted 16, but I measured against a stock 200 to see how much taller it is. I'm sitting 4" taller than a stock truck, and the top of the Maxtrax mounting pin is the tallest thing on my truck which measures 82.5". Subtract 4" for the lift and 4" for the Maxtrax pin, and that would put the height at 74.5". I'd call that within a rounding error of being accurate on Toyota's measurement.
Builds - mcgaskins' 2016 build thread - Ruby
