Driving down the road on Wednesday. Big bang under the hood
and lots of noise. Pull over and the fan blade is cracked and
partially missing, the water pump is broken and coolant is going
everywhere. Fan shroud has a nasty gash.
I'm running again but want to know what went wrong. Two
theories:
1. Fan was cracked. The crack spread and allowed one of the
blades to fly off, hitting the shroud, which kicked the fan back
and broke the water pump. If you look closely at the fan, you
can see that part of the blade has a crack which is bright and
shiny (thus new) and part of the crack is old and rusty (which
means it has been there for a while).
2. Motor mounts are broken. I still have the old round motor
mounts and they don't look that great. The broken motor mount
allowed the engine to move far enough in the engine bay so
that the fan hit the shroud and then the whole thing fell apart.
Note that I cannot see the engine move one bit in the engine
bay when I rev it, but this is not under a full load.
So. I'd like to know what happened so that I can prevent
this from happening again.
theories:
