I'm in the process of correcting my rear pinion angle. Since lifting my truck and running relatively light most of the time my rear pinion to transfer case output flange have a 2 degree variance. My truck sits at 25 1/4" in the rear from hub center the fender. Does anyone know how much I need to shorten my upper control arms to correct for this? .....
my other approach is to put the rear axle on jackstands, pull the upper control arms and use a ratchet strap to rotate the axle forward until the flanges measure even, then measure the length from frame to axle and have a shop cut and shorten the arms.
Any advice is greatly appreciated. Thanks
I don't see myself selling the truck any time in the near future and don't imagine I'll bother trying to return it to stock if I do sell it. I've already cut the rear cross member for the 4x4 labs bumper and done caster plates! ....and all the adjustable arms seem awful expensive.
