Upper hatch won't latch closed.
Central Point Oregon
I came home from work about a week ago and had some items in the back of of my 94 LC. I opened the upper hatch pulled the items out and closed the hatch. I noticed immediately it did not latch. I opened it again thinking some how the lower hatch had opened somehow causing a problem. No dice there. I checked the mechanism it opens and closed freely. I thought maybe the striker was out of adjustment, but there is none. I loosens the mechanism and it latched closed. Almost appears to me like I am missing a piece of plastic on the mechanism but can't be sure. Any help or advise would be great.
Did you (or someone who "borrowed" your truck) back it into a garage door frame in the open position? :o
You probably checked this already but, my latch for the top hatch tends to stick after opening - sometimes I have to push it to the "closed" position before shutting the hatch or it won't latch. If I forget to do it, sometimes it will latch, but the power lock wont lock the hatch, I guess the latch itself sticks kind of in between and the lock won't go, like someone lifting a door handle at the same time as you do the power lock.
