New to this forum and its operation. Also my understanding of Cruisers and the year/model differences is very low. Figured I would post as I haven't found much info searching here yet (so many forums)
This is a link to my Pirate build so you guys can get a idea on why I want something like these.
http://www.pirate4x4.com/forum/toyota-truck-4runner/731541-blueberry-krunch.html
Im researching axle options for my propane turbo powered crawler. The stock mini 6 cyl rear and HP 8 just are not cutting it.
Im looking into a 9.5 chunk with a load bolt. Rear would be a centered axle with 35 spline Toyota hybrid shafts. To my knowledge a 12 bolt spool will work as a locker for this rear application.
Front would have the same 9.5 chunk and a load bolt. It would run FJZ outers (hellfire knuckles and the super new 30-30-30 spline FJZ chromo axle set from Longfeilds)
Of course this is all very expensive. I have talked with Brian at FROR about diamond axle housings already but they are expensive. I think that I would make my own housings if possible.
So with that whole story written can anyone post up some links to anything that is similar to this from here? I figure I would start with info on centering the rear axle.
