Upgraded front and back
Orange County
My plan was to install new rotors but one of the bearing hub studs came out so I aborted that project and installed the high clearance caster correcting front radius arms and the high clearance panhard lift bracket.
Thanks Delta Dave.
Are you having any issues with the top bolt Nut rubbing your spring. Your supposed to install with nut on rear of truck. I have been with a couple of trucks that had rub issues.
It’s close but not touching the spring. So far no issues regarding rubbing.
