- Joined
- Jan 22, 2008
- Threads
- 44
- Messages
- 148
are there any upgraded brake kits for the 80 series landcruisers? i know with a tank like this, you can use every bit of help in improving stopping force.
If you look around you can find Brembo Rotors for about $100 a set (normally about $400 a set) they seem to have made a lot of them and are clearing them out.. you can also find EBC green stuff brake pads that work awesome with the Brembo rotors.. add these to the other suggestions about a flush and stainless lines.. Make a HUGE difference when your done..
Rotors front $120 ish
Rotors Back $ 150 ish
pads around $ 100 for 2 sets. One set will do both front caliper
lines are around $130
Check Ebay they get the Brembo fronts often, the back you may need to work a little harder to find..
good luck..
I don't get why everyone is all weird about brakes. I have stock brakes: OEM 80 series pads, OEM calipers, OEM rotors.
My rotors are almost 4 years old, they're warped a little bit, and they squeak like hella. I haven't bled the brakes in the 25k miles I've driven my Cruiser since owning it. I'm not sure when they were bled before then.
I've changed the front pads twice, and the back pads once.
I stop like a champ. There have been a lot of times when I've had to slam on my brakes, but not one time, even while tailgating someone has the stopping power been an issue with my 80.
Lockd97,
Besides longer pad life, have you noticed shorter stopping distances or other improved performance using the DBA's?
OK, lift it, put on some 35" tires and add another 1500lbs of accessories and gear and see how well that champ stops.
