Upgrade Options?
Hey guys new to the cruiser world. Have always wheeled jeeps but have always wanted a cruiser.
Just came across a gem. 1993 80 original owner with 102 on the clock. I couldnt turn it down.
I plan to use it as my daily driver and part time weekend warrior.
I have been looking for different lift options and tire size.
It has the original 16" wheels which i plan on using.
would like to run a 33-34" and keep them inside the fender wells as much as possible.
any favorite tire sizes? 285s just look to small and not really wanting to run 315s everyday
would you go with the 2.5 OME kit or would you upgrade and get the J springs?
how much clearance would the j springs give me over the basic kit?
sorry for the somewhat elementary questions but this is a new can of worms for me.
Thanks in advance
Welcome to the cruiser world! I have 33" BFGs at stock width and I've been happy with them. You can fit them without a lift but you do loose some flex. I used a TJM 2" suspension lift with 9 way adjustable shocks. I've been really happy with it although I did have one of the shock adjuster dials break off on a rock. Good luck with your build!
from your description of intended use id vote get the standard 2.5'' ome or 2'' TJM progressive and 33s
I would not go for J's.. they will net almost an inch more lift but get you into castor/vibe areas. KISS method
IF youre not running 35's then there is no need and if you want to later you can run the 35 on 2.5'' just fine..... or swapping springs is relatively easy.
oh and welcome :flipoff2: congrats on the low mileage cruiser!
there is a 295 if you want the tall and skinny at 33.8 or so but remember a 315 is only 34.6 and not that bad to dd.
255 is another option but a little harder to find if you need a spare while away from town.
Pop in and say hello on the NC clubhouse.... you just missed our meet and greet this past weekend with about 20 80s of varying levels of builds plus an 44, a 73 and an LV. Lots of folks for you to compare rigs to in person. Depending on your location you may try and make a monthly meeting where you could look over different rigs before making the decision.
https://forum.ih8mud.com/forums/nc-olde-north-state-cruisers.54/
If I wanted to stay under 315 then I would definitely get the 285. The main reason is availability. If you get out and about somewhere and lose a tire you will be able to find that size just about anywhere. When you start getting into 34's and skinny 33's you start losing in store options. If that doesn't matter to you then get whatever. On the same note if the 285's are to small for you then just go with 315's.
Thanks guys for the responses. sounds like the 2.5 OME is the right choice. this will be a slow build for me as funds become available. i will try to document the build as i go.
Need to consider? Absolutely. Need? Absolutely not.
Be glad you re-geared (if you ran 35's)? Most likely. Be satisfied with stock gears with 35's? Most people are.
I had a similar upgrades in mind. I went with the TJM 2.5 and Tiger Adjustable with 33. I love being able to adjust the ride for the conditions. You can see the ride height in my Avitar Picture.
Weight of tire makes a huge difference. Duratrac 315 are about 63 lbs where others can go up to over 80lbs.
I had 315 Duratrac and it was fine with stock gearing imo.
I went 33s first on a 2.5. Great ride and didn't feel like regarding was necessary. Then got to deciding they were too small. 315 definitely look the best imho. Agressive but not over the top. You do feel a desire to regear driving through the mtns.
I am running 315 now and it goes just fine, for a 6000 pound iron pig with a straight 6 engine.:deadhorse::deadhorse::worms::worms::worms::worms:
315s, 4" lift, stock gears and I'm closer to 7000# now. No issues with mountain roads or power or speed...ok the SC helps alot :flipoff2:
IMG_1545.webp IMG_1543.webp Little late on posting this but here is my cruiser as I bought it minus the racks I had in the garage I threw up on it last night. Pretty clean for a 1993. Hopefully will start the build soon.
