UPDATE to my no start issue
Update to my no start issue after replacing the valave cover and PHH
Will not start after valve cover gasket replacement
So I started some maintenance work last week which turned out to be a major headache.
Things to be replaced.
Removed the air clear and attempted to remove the VAF/MAF Sensor, by the screws, (BIG MISTAKE, I later learned), just tmo ve out of the way. The connector plug did not come out all the way, so I pushed it back in and kept going. I left the cables attached to the throttle body and just cleaned it in place. I installed an Air/Oil Separator 2 weeks prior (everyone should do this). I removed the valve cover, 2 of the spark plug guide gasket stayed on the truck. Unknown if the valve cover has ever been off, numerous cracks in the valve cover gasket, which would be the cause of my oil leaks.
Up till now everything seem to be going as scheduled. After everything was reassembled, the truck would not start, so I rechecked all of the plugs (3), vacuum line, the MAF senor and it still would not start. Got some real time help from the guys here on IH8MUD and started to check several different things.
With the help of Kernal he suggested to see if I had the check engine light, NO Light. With that information he suggested to check the VAF/MAF to see if I had damaged it when I tried to remove the plug. Well I found another thread on here about not removing the screws and to pull the small wire clip, which hold it in. That was my BIG MISTAKE, there should be some sort of warning label on those screws.
Trying to find a VAF/MAF for a 1994 Land Cruiser sounded easy. However no one remanufactures it or has a rebuilt one in stock. I did find out that you can send it back to CARDONE, through one of their parts stores (NAPA) and with an 80% chance they would be able to rebuild it with a 3-5 day turn-around.
I pulled the VAF/MAF off and attempted to see if I could fix the problem myself. Well when I pulled the screws out I torn 3 connectors from the computer board. I straightened the wires and attempted to re-solder the pins back down and resealed the cap. Whalla with that fixed the truck started right up.
Note prior to this I had engine code 52 & 71 that would not clear. Now the codes have been clear for several days, fingers crossed they don’t come back.
- PHH (replaced by the previous owner, unknown when)
- Valve cover gasket
- Spark Plug gaskets
- Throttle body gasket
- Remove upper intake to clean
- Replace misc vacuum hoses
