Update on caster correction kit
Last week I posted about a weird caster correction sleeve that I found in the DS knuckle during a rebuild. See thread: https://forum.ih8mud.com/80-series-tech/205160-has-anyone-ever-seen.html
I went ahead and put everything back together the way I found it with the intention of having a good alignment shop look at it. I took the rig in on Friday, and we found a 1.5 degree difference in camber from the PS to the DS. I explained what I found, and it was recommended that I remove the sleeve and put everything back to stock.:bounce:
I'll be ordering some more parts, and doing it right this time! The good news is that my axle is straight.
I guess that the work was done to generate some extra income for a slow shop?
Not really. Contrary to what may have been posted on here, those offset trunion bearings are not a band-aid fix. They are made by a reputable company, and are indeed a viable method of achieving some adjustablility (or fine tuning) on a solid axle. Don't have them in mine (no caster/camber issues), but wouldn't hesitate to use them if needed.
A couple of observations from my situation.
This may be a viable fix for a light weight car that sees no offroad abuse. The replacement bearing is at least one third smaller than the stock bearing. There is no way that it will hold up as well as the stock bearing. In my experience, Toyota over engineered pretty much everything in the Landcruisers, and I am happy with this. Why would I want to "degrade" a critical part?
Second, the fix was only completed at the top trunnion bearing. There was no attempt to keep the knuckle housing centered with the axle housing. Only one point in the axis was shifted, and this has lead to noticeable wear in certain parts. The inner axle seal was worn only on the front edge, and this would lead me to believe that this seal is compromised, and will fail prematurely. I also noticed that this setup shifts the knuckle housing forward at the top. This leaves a gap at the wiper seals at the front of the knuckle, and the metal wiper seal rubs at the back of the knuckle.
If needed, the correct fix would have been to split the correction with the top and bottom and keep the knuckle housing centered with the axle housing.
I agree that this can be a viable fix in some cases, if done properly. I don't like it on my vehicle, as I intend on using the truck for wheeling. I want strength and reliability. I also need the assurance that I can complete a trail side repair without having to order a funky size bearing.
The alignment shop confirmed that the axle housing is straight, and there should have been no need for a correction like this.
Good on you for making the effort on confirming your suspicions. Let us know when everything is back to stock and how things are looking at that time.
After I repair it, I'll be taking it back to the alignment shop once again. I'll post on the results.
Jeff,
Didn't realize the PO had butchered the job that badly! Sounds like you were lucky to catch their "handy" work before you started breaking stuff.
I should have been more specific in the description. I'll post some pics of the two bearings together so you can see the difference.
CDan, can I purchase just the trunnion shims? Will I need an assortment to play around with pre-load to get it right?
Times like these, it's nice to have a lifetime alignment from the shop!!!
I've been using the same alignment shop for years. They don't charge me to do a quick check up.:cool:
