Gents, I'm a bit stuck on how to proceed with fixing my driver's seat.
Last night I finally got around to installing the Landtank extenders, and those went on without a hitch. The extra leg room is fantastic!
But installing those extenders and the ensuing extra leg room pretty much solidified a fear I've had about my seat for a while now.
It seems as though the right front corner (as you sit in the seat) sits up higher than the left front corner, even with the seat all the way lowered with the power mechanism. Almost like the lift/lower mechanism is not aligned properly to balance each side. This wasn't as noticeable without the extenders for some reason, but now that I'm sitting further back, it becomes way more apparent.
The seats were re-covered by the previous owner, and I'm wondering if the shop that did the upholstery maybe didn't re-assemble the seat gears correctly? Or maybe the front left corner has been bent down by 20+ years of big asses like mine getting in and out of the truck?
My question is; should I take the whole thing apart to see if there are gears used for the up/down movement, and try to adjust? Or will taking it apart screw anything up?
Perhaps the seat frame is bent, and I can straighten it?
Before I tear in to this thing, has anyone else noticed this problem?
It's maybe a 1" difference from left to right, but I have a 45 minute drive to work, and by the end of the drive my right leg/knee are killing me from being pushed upwards.
