Underside Tub Front Floor Support
Calgary Alberta
I've just ordered a front floor support from Real Steel Land Cruisers, to replace the missing drivers side support. Not sure why it was deleted by the PO, possibly during replacement of the floor pan.
Can someone advise me on the correct installation procedure? Spot tig weld into holes drilled into the flange on both sides, or a bead down the length of the floor support on both sides?
Appreciate the advice.
As you first suggested, I'd do 'plug' welds to mimic the OE spot welds.
Thanks that helps. Would like to resemble OE as much as possible, its hard to see how they went in originally due to rust / grunge.
