Undercarriage opinion
Philadelphia
Happy Monday folks. Came across a 2000 LC with 150k miles... here's the undercarriage. Reportedly had "rust removed/coated -- no issues". The truck looks like it's in great condition, and this is the only thing I'm curious about. Any help is appreciated. Thanks.
i just had mine re-mediated and treated when i bought it- mine looks a bit cleaner, but i think that's due to the potential depth of the rust and how much they can scrape off. Ask for receipts on the remediation (mine took 5 days and cost about $1,200 as a reference)- if it was done properly (looks like it was at first glance) you should be totally good to go. It doesn't look like much damage there- just typical stuff at the factory welds.
wouldn't scare me off as long as there were receipts from the work done by a reputable shop.
bertnd has the right idea with the receipt/proof.
Rust remediation might be great if done properly. However, it immediately makes me think "cover up" if you're selling it recently after the remediation.
I'm from the south, so to me, that thing looks fairly rusty with some "rust converter" sprayed on it. But I'm definitely not a good point of reference.
Hard to say from just this one photo, but doesn't look like a proper job - you can see patches of visible rust and where it is painted, looks like they just sprayed over the rust...
Pass.
While this doesn't reek of a cheap job, it doesn't look super professional either. I can clearly see rust underneath the paint. I mean, it's literally right there.
What is the mileage? Interior condition? Service records? Price? Are you willing to travel or not?
These are the key questions, basically.
For the right price (maybe $5k?) I'd say it's fine. Definitely no need to pay a premium for relatively low miles though. It's a passable job of remediation, but will likely still rust where it had rust before. I think you have to ask yourself, would you buy it if it had visible rust where it's now black, because pretty soon you will.
here are a few pics of mine- i couldn't get the best shots because i'm in a parking garage with low light and didn't really want to get my work clothes dirty.... as a note- i didn't have them do my spare tire hanger either- too hard to scrape and treat- it's just better to replace it. According to my shop, the rear diff/axle is always the toughest to treat for some reason. Mine still looks a little bumpy, but i couldn't get a good shot of it- maybe not quite as bad as the one you pictured above, but not perfect either. here is a shot of my frame rail next to the rear tire. it should basically look like a smooth, new frame with a good coat of black paint on it. the paint you see isn't really anything special, just a standard undercoating/rust preventer. The rust inhibitor magic is on the coat underneath it, which stops the chemical process of rusting and converts it to a hard, porcelain-like surface. second pic is what your sway bars and other round bars should look like if they're scraped really well and still solid, and have a little dirt on them. (sorry for the dirt- nature of the beast :) )
Living in the rust belt I tend to think that they just sprayed over the rust. Doesn't appear they scrapped, wire wheeled or any means to clean the surface prior to treating. On that fact alone I would pass. I was realistic when looking for mine and looked at a few that were listed rust free and looked like this. I figured if they were lying about covering up the rust what else are they not disclosing. I ended up finding one out of state that the owner was upfront about the rust but he kept it in check and treated yearly so it was truly just surface rust and has stayed that way even though it requires me to do yearly clean up and treatments. Good luck
@racebannon i'd worry more about the title issues- being repo'd is a potential worry but not the biggest one i see- i can honestly say after looking at probably thousands of carfax reports, this is the first time i have EVER seen "collision with a train" on an accident report. I don't know how the car can win that one!
Here it is. Looks pretty good minus whatever is possibly going on underneath.
You were considering that LC100 for $15+k? Seriously? No man.....just no.
The work that he's put into it is just regular maintenance. Also new muffler is a redflag. Means rust. For $15k, you shouldn't be getting any rust. 120k miles and 200k miles, difference mechanically is marginal on a 100 series besides more interior rattles, steering rack bushings/leaking, and the dreaded $2500 master cylinder.
No!
^^ I agree with this ^^
A 2000 LC in great shape with zero rust still isn't worth $15k in my opinion. I bought a 2005 with 131k, zero rust, up to date on all maintenance, and a relatively clean interior for $15k last May. IMO, that should be in the $8k range.
