Under hood welder...
Yeah its actually pretty common. Just not on 80 series cruisers. You could do it on a 40 or 60. Premier Power Welder is pretty much the only option for 80s and they are spendy.
I did a similar setup on my fj40, basically used a rebuilt alternator and mounted it where my york used to be, fabbed up a bracket to have it run off my serp belt, so now I have 2 alternators, one standard and one that is a welder. I also installed and engine rpm knob in the dash as you have to increase rpm's to make the welder work correctly. I will try to find the link to the writeup I did. I would think you could do the same on an 80 if you could find a place to mount the alternator.
Noah
I seem to recall a post about someone mounting two alternators (though both for power rather than welding).
They probably didn't have a York or SC though....
