Under dash wiring...
Newberg, Oregon, USA
I would like to get at two of the shorting junction connectors in my 1991 Landcruiser, J2 and J4, but am not sure what it is going to take to get at these, and I wonder if anyone here has experience getting at the wiring up under the dash.
Here are some reproductions from the factory wiring manual for clarity. This shows where the two connectors should be located:
And a close up...
Here is some more information about these junction connectors and what they look like...
The trouble is, when I look up under the dash, I can't see any of these connectors. There is one large taped wiring bundle about 25mm or 30mm in diameter, quite tidy packed up high, and above that there is a black rubbery felt-backed sound barrier blanket that seems to be captured up under the dash. That sound barrier looks impossible to get past. I can't tell whether these junction connectors are above that sound barrier, or taped up in the large wiring harness bundle.
Do I have to take the entire dash down to get at these two junction connectors, or can I get at them from underheath by un-taping the wiring bundle and then re-taping it.
It is no fun getting at this stuff in any case, I am just trying to figure out what's the most expedient method.
Anybody have some experience with the under-dash wiring?
I guess I could add that these rigs are so well put together, the wiring is so tidy, that it can be hard to find things when you want to make a modification. If this were some other brands you would look up under the dash and find a rats-nest of wires and the two connectors I want would be right there in plain sight, but they would also be more vulnerable to damage then.
I am also going to want to get up in there to replace some of the dash indicator lights, but that can come later.
Thanks!
I've been under the dash of my '91 waaaay too much...
There is a removable heater duct behind the lower dash panel, underneath the steering column. It takes some work to get it out, but once it is out, the whole underside of the dash is easily accessible. This may be what you're referring to as the "sound barrier"?
HTH
-Lane
PS- I have to agree, it's hard to find things under there...
In addition to what Lane wrote, if you remove the driver's seat (4 bolts) it makes it WAY easier than trying to contort your torso when getting in there. Plus you get to collect all the quarters that have dropped down over the years. When I was working on the rear heater fan I found almost a dollar in change.
You can get your hand all the way to the instrument cluster. I've done this when replacing the speedo cable. IIRC there is also some steel framework behind some of the plastic panels that will slice flesh easily. Once you clean up the blood it will make a good gound point.
I don't remember seeing a heater duct up in there. Unless maybe you mean the stuff behind and below the radio. From the wiring manual illustrations, I envision that these connectors are more behind the right end of the instrument cluster.
I have managed to get on my back with my head way up into the pedal cluster, literally using the gas pedal as a head rest (and the brake pedal as a Q-tip in my ear!). I will try to get a picture up under there. The sound blanket is like a thick flexible dark grey flat plastic sheet with one inch of felt on the back side, that covers the firewall and goes right up till it gets trapped by the dash framework. it is actually trapped by all the bracket work, so if the connectors are on the other side, it would take dropping the whole dash I think (ugggghhhh). It is clearly not a duct.
I don't recall seeing anything else visible up there except that one fat wiring harness bundle, all taped up. I suspect that the connectors I want may be wrapped up in that bundle. What I remember seeing doesn't sound anything like what you've described. I will have another look and will have to try to get some pictures.
Thanks!
-ts
HTH
-Lane
I found over $4 when I gutted my interior a few months ago. And a bunch of Cheerios. :hhmm:
I grounded my remote entry system, light relays, and several other things on a piece of steel up there... It's a VERY good ground point.
Oh, THAT... We're thinking of two different things. :lol:
Although, if you remove the lower dash panel and the heater duct I mentioned, things will be more easily accessible. Even more if you remove the driver's seat, as Jon mentioned. I know there are some connectors up there that I could not have gotten to without removing the duct.
dash wiring...
Okay, I figured out how to remove that duct, and it does help a lot. Didn't get to the lower dash panel. I guess that is maybe just a few of those screws along the lower edge?
Still can't see the shorting jumpers I am looking for, but I am pretty sure they're going to be bundled in that fat wiring bundle under some tape.
Thanks!
IIRC, there are four screws holding the panel on. Two are on the bottom of the panel, one on each side of the gas/hood release levers; one at the top of the panel, left of the steering wheel; and one on the bottom right corner of the same panel.
HTH
-Lane
Not going to be able to get at J2 and J4...
Well I have decided that I am not going to be able to get at J2 and J4, but I went back and studied the prints somemore and I found a better way to skin this cat. It turns out that J2 and J4 appear to be above some major structural steel above the steering column. I believe you would have to take the entire dash down to get at them and it isn't worth that.
I will try to post some pictures here later of what I am doing. Want to finish it and test before I publish it though.
Thanks for the help. Taking out the duct piece and lower dash section made it much easier to do this.
Cheers! Back soon.
