- Joined
- Oct 1, 2008
- Threads
- 24
- Messages
- 311
So I'm going camping in a couple weeks and want to take along my Coleman thermocooler. After searching and looking at the different threads, I came up with this not-so-often used setup. I'm thinking I'll take along two extra batteries, wire them in parallel, and use them to power the cooler while parked (can use normal system while driving). Once they discharge (I need to calculate the amp hours still), I'll fire up the truck off its main battery, hook up jumper cables from the main to the extras, let it idle for an hour or so, and hopefully I'll be good to go for round 2. I'm hoping for 24 hours out of two batteries so hopefully I'll only have to fire the truck up for about an hour a day to keep my cooler going. I'll most likely fab a battery tray tomorrow after work and get it installed, and also make a parallel harness (with fuses) for the 2 batteries. That battery will be sitting in a nice shady spot outside the engine compartment but not in the truck or other enclosed space.
For a more permanent solution, I found a NOCO Delcotron isolator in my mystery box that I bought a few years ago and plan to install it after the trip. Hopefully it'll work even with an internally regulated alternator (our's are internal, right?). In case the main battery dies, I can always hook up J-cables between the two, wait a few minutes, and fire it up.
Does anyone see any flaws with this setup, other than the crudeness of it all? Thanks in advance!
