un-lock the hubs?
Crime-free Southwest-Houston
Wondering if any of y'all have done the hub conversion to unlock the fronts? I have read some of the thread of removing the front driveshaft and was wondering how much it really increased the mileage. (don't recall off the top of my head). Anyway, looking to gain a little more mpg's and wanted to collect y'alls thoughts, comments, and suggestions.
Thanks in advance,
Tommy
:beer:
I don't agree with just bolting up free-wheeling hubs. IMHO if you are going to put FWH on you need to put the whole part-time kit in, which means installing the solid spool in the centre diff and using the CDL button to engage 4wd. Either have fulltime 4wd or part-time 4wd, not a bitsa.
It sounds to me like not all US spec 80's came with the CDL button, is that correct?? :hhmm:
I put some mile marker hubs on and dropped the front driveshaft. I did not like the way it drove(very loose), my gas mileage did not noticeably improve, and the driver's side hub failed less than half an hour into the first trail at GSMTR. I would not recommend it.
that was b/c they were MM's though, not unnecessarily that it was b/c it was manual hubs altogether.
Just in case someone is searching for this I feel its important for them to know that Aisins are a different class of quality than MM's.
90% of our 80 series cruisers are part time and is very very rare to see a failing OEM Aisin hub.
Actually I'v seen warn hubs blow .. but never an AISIN hub .. ( even with 37" ARB + chains )
I recall at least one on a FJ40 Chevota 350 and one on a FJ62 !!!!!
The CDL mod has been done but the truck is still gonna be full time 4wd unless the viscious coupler is changed right? What is the ratio of the split? 60-40? Or is it dependant on the coupler and the load it is under? Still fairly new to this truck (had it for just over a year now) so still learning new stuff about it all the time. I'll check out the thread.
I see that the fuel savings may not be much but to save wear and tear would be a plus.
:beer:
Plenty of info about the CDL and VC around here ..
The 40 - 60 - 62 split case BF1A come in 2 flavors .. 196:1 or 2.28:1 there is a splitcase in the auto 62 that come with 2.48:1 as same as 80 series HF split case series ..
FWIW, I had the hubs GIVEN to me for FREE and I am still running AWD. I tried running 2WD on the way out to moab and saw no increase in milage. I still have the hubs bolted up because they will fail before a birf will (or so I've heard) and they look cool.
