Ultra low gearing
Fairfax, VA
Saw this on Zuks site. Maybe you guys running the 38, 39 tire could use these.
:cheers:
These are good gears...I just don't know exactly where they come from.
Update 4-30-2008: I know a little more about this gear....AM is for Antonio Masiero Gears. I downloaded the light duty catalogue (click on the catalogue icon at the bottom of the main page) and noticed that 6.83 gears(6 teeth on 41) can be had for the Land Cruisers with the 9.5" gears. wow
Antonio Masiero its a popular Itailan producer of gears .. pretty common in Europe and Africa .. but 6.83 .. how tiny will be this pinion ? :eek:
gears
Antonio Masiero is a gear MFG, they do not stock gears. They may have been made at some point, or possibly still made for an odball application. My guess would be Forklift, or Airport vehicle? There would be little to no demand for this low of a ratio, additionally in the case of an 80 series front gears would have to be made. It takes commitments of several hundred sets of each ratio, so I wouldnt count on it. Also, the pinion would be TINY.
:cheers:
:D x2,
I've seen good'ol Yoter forklifts push @ 15-20 pallets IN A ROW, loaded w/ sales paper inserts, on dry, smooth concrete :eek:
I just gotta make sure he's paying attention. Anyways, I'm sure he'd say, "6.83s aren't that bad...":D
Hmmm...maybe a little bit low for 35's.
Not an option for the front, although good ratio. Guys going big on 80's will be doing Dana 60 fronts/rears with 6.99's in a couple years running 39's+ as daily drivers :D
Sorry I was out of the loop for a bit. I didn't expect you to run 35s. I know the Trxus comes in a 38.5x14.5r16...:rolleyes::hillbilly:
