I think you're a candidate for the "IdahoDoug stupid Cruiser brake trick of the week".
Put all four corners on jack stands under the axle on a flat level concrete surface with the tires not touching the ground. Start it, engage the lockers (low range if you don't have lockers or the locker mod) and run the vehicle up to 30mph and engage the cruise control. Get out and see which tires are out of round or perhaps a rim bent. Nothing notable? Step 2.
Shut the truck off, remove the wheels and again run it at 30mph. Go to each rotor in turn and carefully take a screwdriver held against the caliper (side where rotor comes OUT of the caliper so it can't get sucked in) until it touches gently and use fine movements to see if the rotor's out of true. Do it on all four rotors.
After this, you will know if your tires/wheels/rotors are running true or not and have a huge part of the mystery eliminated. I think you'll be surprised what you find.
DougM
PS - If you are maimed or killed by this, then you should know better than to take internet advice. Do not attempt this without proper safety procedures. Void where taxed, prohibited or otherwise regulated. Contents may have settled while shipping. Do not use a knife to open this package. Do not ship cash, blood or valuables in this package. Your vehicle's stability system is designed to help maintain control, but it cannot defy the laws of physics. Your mileage my vary. For comparison purposes only. Do not place this object in your ear.
