Tx case input shaft nut question
Seattle
The large nut on the input shaft; does it require a washer? I put the nut and washer on it and it appears the nut extends too far off the shaft. Seems more appropriate without the washer, especially since the nut has a washer flange of sorts.
Photos attached, Thoughts?
Something fishy going on, is bearing race and bearing seated? Doesn’t look right.
Unfortunately dont have the original combo. In searching the interwebs, it appears this style of nut is used independently of the washer, as it seems to have one built in.
I'll keep researching.
Thanks!
Idk, which is right. What's the original nut look like? Is it shorter, does it have a washer face? If it's shorter and lacks a washer face then my guess is you wouldnt use the washer with the new nut.
