so how did you set up the carb after you rebuilt it? I usually set the idle mixture screw turned out from seated 1 1/2 to two turns. and the idle speed screw should be engaged with the throttle plate linkage.
also check to make sure the gasoline level is 1/2 way up the sight glass. If your float is set too high you could be flooding the carb at idle.
