Had the cats spun. The center flange was removed, welded together in the middle and now each end has a flange with easily removable nuts (nickel anti-sieze on the threads) so that I can drop the cats and service the rusty rear heater tubes (on the way from CDan
) that lie above the heat shields.
Question:
Do the bolts that are used to hold on the heat shields terminate inside the cab on the floor pan? I expect these to shear off since they are rusty (PB Blaster is in use but ... ). I also expect to have to pull the PS seat and carpeting to replace the bolts. Am I in the ballpark on this?
Thanx in advance.
) that lie above the heat shields.Question:
Thanx in advance.
will appreciate the extra heat
