twin stick shifter issues
Lancaster, CA
Has anyone put the AA twin stick shifter on a split transfer case? I have a split case going behind a 4L60E with the AA adapter and AA twin stick. I cannot for the life of me get it to shift from 2wd to 4wd. I put the new gear selector from 2wd to 4wd on the shift fork and put in the case no problem. Once I went to put the gear assembly back on it was a bitch! The gear ring splines didn't want to match up the assembly. I had the fork in 4wd to keep the ring from moving around. I tried to jiggle that sucker to get them to line up, but it's just super tight. I had to tap the selector shaft back into the housing to get it grab the assembly thus putting me in 2wd. So, now I can go from 2wd high, to neutral, to 2wd low no problem. Once I put it in neutral I can't get that thing to budge. I even took out the detent, but that made no difference.
