Tween - More than ten less than teen
"momma said they was my magic shoes"
CL score!!
WOW! On CL? What a find!
They gotta be hot...
And on the upside, you made it home without any bullet holes.
If Alabaster has a ghetto... It was this place.
Absolutely, DAN!
So the front end of Tween the DDigger is making a TERRIBLE squeaking noise... and I've had rotors/pads waiting for a tear-down as well as bushings for the rack&pinion. Also a CV shaft to replace the broken boot one.
So last a couple weeks ago I ordered the Slee dif drop bracket.
After the last few days and the front end feeling like it's about to fall apart, I took an emergency day off today. Thought it intially was only going to be a morning off. But it got from decent, to bad, then worse. But at least got it back on the road.
And, sadly. The squeak is not even gone. Appears to be in one of the ball joints or bushings for the Upper or Lower control arm. It's cheaper to buy the control arms as whole units WITH the bushings and balljoints. So I'm prolly going to go that route.... in a few weeks. After the Mardi Krawl, and hopefully the wallet will stop hemorrhaging. Cause it is right now. Badly.
Oh yeah, AND in putting the rotors on, one of the past rotors was cross threaded in a bolt or two so the hub is fubar'd... 2 of the 5 bolts are, so we waited for a machine shop to try to fix it, he could have prolly with a days time, but a couple hours couldn't do it. So now, I'm limping and will need to source a newer hub... and prolly new bearings and seals... FML. this Hunnerd is making me extremely poor.
Suck A$$ man. Hate the tweener is giving you such a hard time.
With 215K on the odo, I think it's just time for some of these parts to be replaced. Just a bad time. Nothing is a good time when it gets close to $1500
To use one of your terms: JEEBUS!! Hope I spelled it right, my haganese is a work in progress. Still waiting on my next Rosetta Stone Disc :D
And there is never a good time, but I'd have to agree at 200k+ miles things probably going to start going south. I will keep my eye on the local pull aparts for hundy's. Some of the late 90's versions are starting to show up every so often.
Out with the OLD
In with the NEW...
