Turning indicators not working.
Australia, Kirrawee
Hoping someone has run into this issue before and has a solve. I have a 2013 70 Series GXL
Today I replaced the 15A CIG fuse. Easy as pie. 12v outlet working again as expected.
I jump in for a drive and notice that my indicators arnt working. Hazards are fine. Everything else seems normal.
So far I have checked the indicator fuse under the bonnet. It's perfect
Removed the newly fitted 15A cig fuse. No indicators
Tried putting the broken 15A cig fuse back in. No indicators
Disconnected the battery, left it for 5 mins and then reconnected battery and tested. No indicators
Please any help would be greatly appreciated
TIA
Check all the fuses. One is still blown.
I shorted the indicators while wiring up and blew the one under the bonnet and another one in the l/h kick panel. Cant remember which one exactly but run your test light over all of them.
Hello,
If I remember correctly, indicators use a separate 7.5 A fuse. Yours is likely blown.
The CIG fuse covers parking lights only.
Hope this helps.
Juan
