Turn signal what to test next?
There is a different connector on the drivers side near the rear corner. I would imagine corrosion is an issue. It was not as much inside where the male/female connection is made, but where the wires go into the connector.
That's where the new Hoppy Hopkins 43405 starts, right? I have a picture, but there was no corrosion that I could see - can you please have a look at this picture?
should I just replace a bunch of harnesses? Does anyone know some mechanic near Danville, VA that might help me in a couple of days before I walk everywhere
I will start treading by foot?
Interesting; had a similar problem with the right rear tail light bulb, the Cruise control would shut off, but only when my headlights were turned on (if a bulb was in that socket), no issue if the socket was empty. Replaced the bulb twice (assuming I had a defective new bulb) and the issue went away (maybe luck?).
Makes me wonder if this is a common issue with that harness connector??
Can you send some luck my way PPPPLLLLLEEEEEASEEEE!
