Turn Signal Switch
Houston, TX
Do the later and earlier turn signal switches interchange? I've got a 69 with a bad TS switch. It appears that from 72 and up, Toyota went to a shorter turn signal stick. Will the later switch work in the earlier vehicle thereby allowing me to get a shorter stick so I don't turn the signals off with my knee? Thanks.
Completely different. Later t/s switch screws down onto a flange on the end of the column; early clamps AROUND the column. Wiring very different too. Totally incompatible.
I have seen a couple of guys that just cut the early turn signal arm down a little. If you do that, make sure and round off the end. :eek:
srestum, I'm gonna pull the column out of my '69 here shortly, if your interested is the turn signal switch let me know.
