turn signal question/problem
Abilene Texas
This is a premature question but i wanted to have as many answers as possible when I start back on this tonight.
The switch seems to work right but the flasher continues to click while the turn signal switch is in netural. I do not have any of the lights wired up besides the dash. And the bake light switch is not connected. Should I expect this issue with the items incomplete as described?
Thanks,
tate
Thanks,
tate
No. The flasher shouldn't click at all if the lights are not connected. I wouldn't worry about this until you want to run the lights as it sounds like you have bigger issues to deal with.
WHAT year? Hook up all your lights, including brake light etc.. Sounds like a ground fault for starters.. The older trucks used same bulb for brake and turn.
