Turn signal prob...
Hi-
Have a 72 FJ40. All lights work except the turn signals. Did a search but didn't really help. Checked all grounds, fuses and all bulbs. When I depress the brake pedal the front turn signals both light up as well as the indicator lights on the dash. The hazards work fine. Anyone have any ideas where I should start?
Thanks!
Perhaps the wrong bulbs in the brake/turn circuit are causing the brake lights to feed back into the turn circuit?
Thanks!
When you say the turn signals don't work, to you mean they don't light up at all or they don't blink?
How did you check the grounds? These symptoms are a classic example of a "floating" or bad ground in the rear brake/turn bulb housing.
Since the ground is bad and the bulb shares a common ground with the running lights, the current travels to the front running lights where it finds a ground.
They don't light up or blink at all with the turn lever, the hazards blink fine. The front turn signals both light up at the same time when the brake pedal is pressed....all running light grounds are good, no loose or broken wires
Either there is a bad ground at the rear bulbs or someone is playing a trick on you by reversing the wires front to rear.
Lol....thats the thing, the brake lights work fine, the turn signals come on as well...its wierd. Just gonna have to start diggin into it I guess...
Just because the brake lights (which double as turn signals) come on doesn't mean that their ground is good. They could be grounding through front bulbs, which is why they come on at the wrong time.
Try momentarily running a ground wire from the rear housing tothe frame and see if the problem goes away.
