turn signal in rapid mode after new wiring (LX470, '05)
Portland, OR
New TJM bumper, so the factory-supplied fog & running/turn blinker lights needed to be wired in. They work - you bet they work -they run 2 or 3X more rapidly than the original turn signal did. Same on emerg flashers. Otherwise all good. I guess I'm fine with this (hopefully still legal), curious if a relay or something else is malfunctioning.
I'm in the same boat with my '02. Curious what people have to say. Thinking of just wiring in some resistors if no one else has any ideas.
they'll probably say we need to stock up on turn light bulbs
yep - they are LED. They are built cheaply, all plastic case that does not snap together clean...be great to switch to something a little more substantial.
Thanks for the lead.
Thanks a ton for the lead. Is your 04 a Lexus?
Right now, because of the bumper, I've got LEDs on front turns, but the rear are oem-type. Did you also replace your rear turns?
Found the JDM Master webpage from your link - this should get me pointed in the right direction, if my LX is different.
Thank you again...
Thanks BEG & big thx to soreneagle for the build vid. My back started barking when he got to showing where the relay is, ha, guess toyota never figured they go out.
I replaced my flasher relay about a year ago after adding LED lights in the front and rear blinkers. Yes it is quite a pain to get to and you will scrape your knuckles a bit, but it's well worth it because that rapid flash was driving me insane! Just an FYI, the OEM flasher relay didn't "go out". The issue is you replaced the OEM bulbs with LED's and they don't need nearly as much power to operate as incandescents. In simple terms: the old bulbs required a lot of power to make them work. By switching to LED's you have that same amount of power going to that connection, but because the LED doesn't require that much it is blinking rapidly. Basically it's sending more power to those LED's than they need. Wow that was very redundant I'm sorry hahah. Replacing the relay will fix this issue.
yeah there is no really good angle, either my hands are too big or I'm too clumsy probably both, so I just pulled off the front dash cover and approached from the front. Still a hinky angle, but easier.
SorenEagle your video made it look WAY easy :) my hats' tipped to any of you guys who remove from below...+1 for agility!
As mentioned, you need to replace the flasher relay to an electronic version when you switch any of the blinkers/flashers to LED. The relay is in a very uncomfortable spot under the steering wheel.
Check out @soreneagle 's video for details:
Thank you @soreneagle !! this worked on my 05 LX 470 perfectly. I just left the stock one on the bracket, and zip tied the new one in, then replaced all exterior flashers with LEDs, really upgrades the look. SOOOO much easier and cheaper than trying to add load resistors.
@OregonB Can you include some detailed pictures of your bumper on your 2005 LX 470? I am currently shopping bumpers and would love to see it up close. Any cutting required similar to ARB?
uiE_Xn9l3HylOJuB64jC9i25EAxsM5JkUfzqjB-YzRGjAbUjURfNmuyxRu6y-LgVkr3CT6n0j2hRufskbgl33wgsGDnBKPn5KQxzImoq0rMCGtpSMnm_QSRibjcOXxjfkX5cToeGH3iomLs2tAUVxLuBIEsQvEGgBhIkugxkGQxtOezuqvAd7wCUwu5JzO3jnfOGZE9SD1Dvh1_LyeOaM6s8PbsqEv88swXwBntR4tH38UOCv-wW_rHNYvXD2BxYhs90bZn1cqaNZ3hZszCEdjs0RzBxcoxUyQJQ4LpVSw8Ho2jsC4zPDKqwUT4EUFP3d4O-86E56fWwc-tX6gI-qSNtez_X1riQSkBYR-Gy0JeZle93KL2FY2p02NYL0LVblCAX9vMqc0iYjEiYBbNi5DkmNT55NbA1bIcXnBYRWEsUZmyuby4wrP8bv0E6Wze5RDRwPkfGTBUyG54mwHdf8wuEhl2Wp-5_BXH302wasgL6f8Obpp-uJyorthWkHvIZyK0cMyzAHSZdrubtYf0Gx7Z9OjL8QhtBvje4DptPzRqDttALls2iVrB3y9V5ti1a_pwWIwNS9y37Ei4z3PAkMq3n8D_4ybLoXFDtX_nl=w2086-h1564-no
hUSv-uZFUE-umYaTSzLOPe-qxtlEwU7WKukwwLAqBkY1E2f8LEoRPBa29n5g2bqy3h2ECSlefTTUVSXJ6dJS6KaVQZUIdbqkTb7lRkLpKJpM8IAO20w_MeNUBvMH8q5VTtbT6jVw7jVw29vzCIINP2i-cwizjDaiaItHPDb8qeFXdxir5do2jb-vpZmwOmhv1u6VYWDCVJvAjZGpD-nkvh-2WkucTXOZ_AN7S9iCLkhq3rETCG-8eUU19Pc6KOy7QUn7yTKebnuS_6O3qzuavfUm1KBVkqRduFUvH0Ce2OyLi-8tHU_P8UgsHufO6dfQ8ffa3H81P9thpQTquHk_ClHOIjNyCUv__ihVbWAKERV2DZj6P4Ld66giD1L3U4WniJagn9Z3XiIISHrEKHfF3zToz90TSBWFRV2wHlDUtNbauivA_A3QsCcyRRlRhqUwSOJnqkXdV_j2syl57t13yUK84jbyR9EbrxXbRwX7bN_JO7lc3Cd1ks6KGVW1EN2RDDwG-IZ26ZqqsnFJuieOXHlbbsrFjMfc3M5nWVcrVAjOrRe63JiZy_LxzIH1o-Ya9PmBcUxBLdpQy6DQfO8qSa4WBkTqhzGhrFURXDR-=w2086-h1564-no
GA2VhWRGV-L90y4c8UsdtGAc_jRIcDYgJBBxOk98XZrj4z83Nfn4RBeZzSBQqBZyO5XxiL2nG8qJuuIIN1HPq8X1OD7OlRhDC-tf1Zun8BPi1z4K1JysULgzUufg2fNbIRWghh4UpblhibwENk5NXxZxpxHhFYl9_N9Qc2NrrJd1N8tqDKnntxGExQVutMhYbwlXRLyQTHAjEfU0lJn3fkdRnJj5XQZLf_rxpvIemDgDfZTfGZmbzMd_oIT9hcSUTlc9o-olrG5clPAO--KuGfFMaQVXlFK_aC9fN6BAEZ2im7CiPwsd4McCCojyzBRybEGPYVS-6m1-PJw7nBHoXXXxKWupP7vF4QTybfP6tRiSqjziPSYvxZr8I2F9MDn6KwkDAFy5qY8up1GZ4jWHdPrlByvsAmzQx4ci8KjrRC5NpripHedG9bUodAuZovgxpwEXmGQz3REqugDjXMuD5wBTKR7JfSNK7W668ZHB3hLmJ2HrpjUz8hinjeyK-0S-J-SyDDfxcL_iyz12kXG0XZOrYl4Hu9guhtLcHipSuRrgU5Oq_I6yA8-edsCa2Cw2cONmYS8cKnTkX300_pCmJq-i8BVBexQnlelzbT9z=w2086-h1564-no
yOv-xs5MKFzDUbc_2PufPMm-9lm-b8T1TsKHlAocRgZn3LdMmN9-BpfyJBvF4f2ywnEADIIbGZIjptI1RWBQXJtzNzbnAmBHfIKNQEV0Euu6h-kUs_-x385oyhUsOeCDRHBdBb2UsxNFuKpJZCrZqQHURISNjK_v2UDDxWUI5n1kxBA6Z8fqnkPqMsXCHD6D1h0xCcDkfoWUy5S27KmgmOHPrxkqBlUHOb8PCqCnq6__MSCtnCHp54Woj4BbA7VQc-9wbLs4LvsNWdeLvC6szDoTpLpQUQpoqSwGfzxmC-914PNBIrOjoM-gA65UoMaHqkP6-x-OchHtBir6YzjS3yHgiROp55Q568hTsTW4BdjzzI-kKRDQzo57D0Ip6vbD0QzGvFuuK_9oROqdLQy0ynzSbgs2-h06ZLuoej5-vNs8p59fbLJb5DGtqrqnMCLL4ycc6D5qvHqwcvy2B51GjuRm72q7iqkSF3n_2Dm2aalgJVpcw2rvst9NzvQa6FTH5jPtQuZf3xY2WGUtOmaN8yifvnM9dB157XhttX9ZVq12tOunpc_34ds57lANpk8ZSB1Uyy6e9-JnD4ZWFGAMuenXvAYJAd2HMGTSdQ1e=w2086-h1564-no
H-Csw9mgoen6DbN7QuOrP_P8VVZ2Q_IBQL3scBu_Wob2ptPXLGpHM54M_7vVxTTMpNvsvjZg8Tp3HcLiZjMgKywSrIUrrcsiFCtDqZD8vPksFvpTxOyUXxYhCdReQfhCjvIz2s-TDCYAKQPEtgKcJ6k6fYaE-oBMdvFg2iWwmBQQw-9lOh0GpZLCsZMFD9Qc6s1cNtLgzhqZ1jYYsY5DM7oCMkvjHKNDvJ9dEw0kZZTBGWUT2LzZq8vLhKJxvYysapf3DmEyffC23hv_XdEIjmezLsB1pcPlyp3LRUsBAb5COHgN0_CQ1JJ0WteSIvIcKRgcrWA1Ci1PmHxR0uFb-IDNRngamAK9LUtT3ReKT_xd_HoSmVpVEs_6QAgsuZ-u6Q93kkFPxhdAQEjBJ9HOb0YBafcK0c9WlIz71hTRj3YZS796HzsRO4Z6R-691ehRyJLCNLnDcqFGr0KxMzdMfvrkoDe2xdJHXh4BqEtZwu_GUwu-aviN7TgrFRZUHnJzf_4TowpINFlpU7st5KRlCxDl_U9TDYycp4nipKma8YFnQ8iEbHroGWxHvmz9jUFvyre4SIShKzBU3iJiaN556fO7vrOyyGnMeSrnsutZ=w2086-h1564-no
ZzQdg2SZhbKT5IeawaLrdfaxNH6ZGSheVY1Q6RllHJEDxxI3O8XYJOEKBqpirwQY61f_RNl5WDqIgHYgU1tac8JpwwnHdHX_ZJOsztcYLzNb2DTqdfzXHJnzmY4li2O01m1VyYZqNL5t2u3dQyfIFbOtjSLYGWoAD-tgiaWfnOzazaT1Xer5OVaw0LZrHi0Zvh6pxXPffV-NKQUEgl4q7OOwSxx5P9TclbxAgA3CoPC17TBRhafWRrvM_8sqCW2YEPUXYhGSeTbvxx_u7YvK_NK6iBrf6_PUk-Z2xwI1ViWtff8gUrgRc4PywPJNjgn7MoL-62GSqtHIjvr6JHa9AwOvObKCaN0Zd1qlhQhkBhk3qZ2hlsMB2iHflAT3wT2jLGlmZ99o4zWPYzuf4w_Ys9m4MHbsCQmP6xOPnVDCyQtMBYzoUdio3EOIlS8IfrwejUemaLZ7IYk-WJNMmnpaDCi_LZuevafiz6tGQxKSFKbIwGdQ8lxAodvRUuawH6qabMzwACN2IdYyScmdkf2-YqKzHXJHHXBgz1WD81AIedMvqlxYlDjPVRWr1TpkpthvK5AiYszgjUe39vYj_CTl47dFvzdOuItJzytDWaF0=w2086-h1564-no
No cutting at all. The instructions I rec'd were geared for the LC, but are pretty easy to translate to the LX. You do drill two holes.
Fitment: This is the only bumper I've ever done, so I don't know what to say about the one issue I encountered: See 2nd and 3rd photos where my finger is between the bumper and the lip of sheet metal on the body. 4th photo also. Gap of 9/16"" on left side, none on right. This is after I widened some holes to work on getting my fitment better, and at one point had a ratcheting tie-down lashed to a doug fir tree and back to one side of the bumper as a come-along to align it a little better. But I'm fine with it; it looks great, and happily this discrepancy does not seem to translate into any obvious visual assymmetry. Let me know if you want other angles on pics.
I would rate this as uncomplicated, but time consuming. I can fly on carpentry work, but give me a 2.5 banana job on vehicles and I'll make it a 4.0. So 10 hours for me, probably more like 6??? for a lot of guys here, not counting the wiring harnesses. Unless you've got back issues, one guy can manage it into place. I did - with the bull bar on - still not awful. B4 I started I sorted all the hdwe into plastic beer cups and labelled the cups, there's a lot of hdwe I found this helped. Go slow and easy with the bigger Nyloc nuts, I stripped 5 or 6.
