97 Land Cruiser. Hazard switch works, all lights flash correctly. Headlights, on, off, work. Wiper arm components work correctly.
Turn signal left / right doesn't light on dash, turn signals do not come on. The fuse is good.
I replaced the signal SWITCH ASSY, TURN SIGNAL with a known good one, no change.
FSM BE-3 states:
Turn signal does not light up. (Combination meter, wiper and washer are normal.)
The fuse tests good,. Switch I believe is good as I put a new, known good one on with same result. Wire Harness?
FSM doesn't mention the Turn Signal Flasher, but if the hazards work fine, is it safe to say that the turn signal flasher works fine?
FSM BE-3 states:
- TURN Fuse (I/P F/B)
- Turn Signal Switch
- Wire Harness
