Turn/side marker
In some kind of mental lapse, I decided it would be great if the Front Turn signals on my 76, and the side marker lights in those Front turn signals would both blink as turn indicators and stay on with the headlight switch pulled like running lights.
To accomplish this I switched the sockets to 1157 GM dual filiament bulbs and it is not working. The sockets for the 1157 has two wires and the bulb has two filiments so I thought one filiment/one power wire and it will ground through the base. To be sure I drilled a hole in my turn signal metal and ran a seperate ground for each bulb. (overkill but I wanted to be sure) So then I took one of the power lines off and got one filiment to work, so it seems that the two wires are one for power and one for ground
But then how do I get the second filiment to light up and have both the running lights and the turn indicators available at the same time?
Thank you in advance
Thank you, that is what I assumed but since I have been unable to get it to work I have been doubting. Now I will start trackinng down wires and find the real problem.
Thanks again
