Turn on lights, engine dies?
38.0111,-109.9181
Website
www.alamosa.fm
Okay, so as y'all may know I have a 3FE in my FJ40. It's a hybrid and runs many 2F parts, including the 2F alternator. So I have it out running today checking everything out and turn on the lights (no upgrade, just standard cheap beams) and the engine dies.
Yes, that 2F alternator is lacking, but I can't imagine the 3FE ECU takes that much amperage to have the truck die? Nothing running, no other explicit electronics other than the mandatory fuel pump. Ammeter does show positive after restart. This happened twice.
Battery is brand new and just taken out of my UZJ100 in perfectly charged and working condition today, so even if the alternator wasn't charging, the battery should provide enough amps for at least a little while, it did run the 100 without issue.
Any thoughts?
Oh yeah, I do have a 3FE alternator that I could bolt in. What is involved in moving to an internally regulated alternator? What wiring needs to be adjusted to get the external voltage regulator out of the picture, etc?
Thanks,
I'd guess that you've got a diode blown in your alternator. It can still charge that way many times, but at reduced output. Not enough to run both ECM and headlights.
What volt readings are you getting before you start it and after. I think auto zone can check it while it's running. Double check your connections, make sure they are solid. Sometimes if the computer does not see a signal that suppose to be there it will shutdown or will do weird stuff.
Make sure that you have a good ground connection between the body, the engine and the battery. I've seen this before. Very poor grounding caused by a broken strap with all of the electrical cricuits trying to work their way to ground via body mounts, shift linkage and whatever. A poor and constantly changing ground with circuits of different draw all competeing with each other, backfeeding and cancelling each other out. All sorts of gremlins possible, including exactly what you are experiencing.
Mark...
